WHEEL WEIGHTS AND BALANCING
Old Feb 16, 2007 | 01:06 PM
U4TSAF2's Avatar
IF I'M IN THE WRONG PLACE; SORRY. AFTER REVIEWING ALL THE THREADS THIS SEEMED TO BE THE ONLY CLOSE THREAD.
1987 TRANS-AM. STOCK WHEELS WHICH I BELIEVE ARE 16" RIMS. BLACK WIRE PATTERN.
THE WHEEL WEIGHTS USED TO BALANCE THE TIRES, FOR MY CAR, HAVE TO BE PUT ON THE OUTSIDE PART OF THE RIM.
THE PREVIOUS WEIGHTS WERE PUT ON THE INSIDE OF THE RIM AND WE'RE DESTROYED ON THE FRONT RIMS DUE TO HITTING SOME GUIDE.
Old Feb 16, 2007 | 01:40 PM
Guest
Guest
Posts: n/a
I'm sorry, whats the question?
Dont use hammer on weights, use the tape weights on the inside of the rim.
Old Feb 16, 2007 | 02:30 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Your wheel bearings probably have some slop to them and are allowing your tierods to hit the inside wheel weights. Put a jack under the control arm and jack up the car, then grab the tire at the top and bottom and wiggle to see how much play you have.
Stock, the wheel weights are pretty close, but shouldn't hit, if you have replaced your tie rods with aftermarket ones they might be slightly bigger and pose a rubbing issue, just grind the offending portion and more on.
Old Feb 16, 2007 | 06:13 PM
Guest
Guest
Posts: n/a
Or if the rear rims are up front they'll rub most struts and rip the weights right off. Just remembered that little tidbit.
Old Mar 2, 2007 | 11:33 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
morrow
Jan 13, 2024 12:29 PM
LT1Formula
Nov 16, 2015 01:13 PM
gixxer92
Sep 1, 2015 04:32 PM
InfinityShade
Aug 22, 2015 08:00 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
