rear wheel spacers or not
Car: 1982,Z/28
Engine: 355
Transmission: t350
I currently bought new wheels for my 1982 Z , and went to iroc size of 16x8.---i need too know, does the lets say 96, 97, iroc use rear wheel spacers ?--my 82 orig had them but was unsure if ill need them with these rims ?? if so after market or stock ?
Don't know if a 96 or 97 IROC wheel will fit... I'm not even sure what kind of car was licensing the IROC name at that time, if any.... Chevy terminated their contract with IROC effective 1/1/90.
If you're talking about 96 or 97 Camaro, then yes you would have to use spacers to use those wheels on your 82. They have a different offset. The spacers would need to be about 1¾"
Your 82 didn't have spacers. Unless it got those little ¼" or whatever ones, that were on there only to make the rear the right width for the auto assembly eqpt to work right on them.
Any wheels that are correct for any 82-92 Camaro will fit your car without spacers.
Car: 1982,Z/28
Engine: 355
Transmission: t350
I goofed, ---i meant the 86, 87 iroc---my car is a 82 and it DID come with wheel spacers at rear wheels. and i added newer 87 stye iroc rims [ 16x8 ]---and need too know if i need the spacers still at rear wheels.
As said, YOU don't need the spacers; AFAIK all that they were there for was to make the disc rears and the drum rears EXACTLY the same width, so that the production line equipment would fit them both EXACTLY. That being an important feature of mass production... for automated assembly to work the best, all the component parts have to be EXACTLY the same, if you want to get EXACTLY the same result on every finished product coming off the end of the line. But there's no "requirement" that they be there, as far as wheel fitment or any of that.
If your wheels are aftermarket, then the whole deal gets even murkier; who knows how nearly EXACTLY some aftermarket wheel matches factory dimensions?
Use them ifi you want, leave them off if you want; as long as it all fits, it makes no difference either way.
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
The thin factory spacer is used if you're running iron brake drums . It makes the wheel sit in the same position as the aluminum drums .
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
