Problems getting center cap into new wheel.
Old Feb 23, 2007 | 08:35 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I'm having problems getting the center caps into my new wheels, they have an o-ring around them and you push them in from the outside. I tried using warm water on the seal and that makes it possible to at least get it in there, but part of the seal comes out of the grove in the center cap. What kind of lube can I use that won't damage the painted wheel but won't let the cap come back out to easily? Here's a picture of the cap:
Old Feb 23, 2007 | 09:39 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You could try a light coat of vasoline on the o-ring to make it more compliant.Also a light coating of cooking oil will work.
Old Feb 23, 2007 | 09:43 PM
Car: 2012 Corvette
Engine: LS3
Oh yeah, I totally forgot about vasoline. I'll try that tomarrow, thanks.
Old Feb 23, 2007 | 11:46 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I'm having the same exact problem on one of my Centerlines, it's irritating!
Old Feb 24, 2007 | 04:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
are you talking about the front caps? i have centerline daggers with the same hub and they fit good and tight on the rear but i had to file out the inside of the cap to get them to fit on the fronts. they hit the hub on the brake rotor and thus do not go on all the way. you can do it with a file or a die grinder.
Old Feb 24, 2007 | 07:44 PM
Car: 2012 Corvette
Engine: LS3
The Vasoline worked perfect! Pubbed it all over the o-ring and they popped right in.
Old Feb 24, 2007 | 08:24 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I'm gonna have to try that. I hate having 1 wheel with no cap.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
kah992
Aug 19, 2015 02:55 PM
Fronzizzle
Aug 9, 2015 01:15 PM
