Bent frame??
Old Mar 6, 2007 | 03:46 PM
firetie28's Avatar
Car: 06' chevy 1500 and 84' z28
Engine: 305 with an unknown cam and heads
Transmission: 700-r4
Axle/Gears: its an open rear 3.48 or 3.73?
Bent frame??
I bought an 84 Camaro z-28 about a year and a half ago. it has been on jackstands for a while with the trans out. i got this as a box job from someone who had a 200c trans in it and the torque are from the rear wouldn't reach the trans. ... I bought a 700 r4 and when i put it in i forund that the trans crossmember that i took out won't fit now, its to long. i may get some spreders and spred the rails out but i wanted some feedback first.
also the doors and trunk all open and shut normaly.. no other signs of trouble. thanks-Matt
tried spreders and no luck.. can someone measure their trans crossmember from bolt to bolt on an 84 z-28?
Old Mar 8, 2007 | 05:36 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
No. Because I don't own an '84 Z28. See ya at work tomorrow dude.
Old Mar 8, 2007 | 07:46 PM
Guest
Guest
Posts: n/a
Sounds weird. Are you sure the crossmember didnt get damaged/bent/whatever while it was off the car? I've had stranger things happen with roomates, friends, and things like water pump pulleys. I dont even know what it was used for in the 2 days it was off my car but it sure wasnt reusable.
Old Mar 9, 2007 | 04:34 AM
firetie28's Avatar
yes
the crossmember isn't bent but it may be the wrong one. the gut i bought it from took an 83 camaro with a th 200c and put it in. the crossmember may have been installed wrong. now i'm tring to find a crossmember for an 84 just to see if i'm right. thanks for the help. -matt
Old Mar 11, 2007 | 10:20 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
im pretty sure 82-83 where different bc i had to get a different crossmember to swap in a 700r4 in my 82 a stock one form a newer camaro wouldnt work
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
