Ride height
Old Mar 6, 2007 | 07:52 PM
mlaudon's Avatar
Car: 89 Camaro Rs
Engine: 355 build up
Transmission: TH350
Ride height
hello guys i just got some KYB struts for my 89 camaro rs and i put them on and the old ones were really bad and then with the new one the ride height now with the KYB is like 1ft high now,, not sure if it is right im sure it is but any pic of yours or information.
Old Mar 6, 2007 | 10:12 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
new struts should not change ride height at all!
How did you install them?
Did you let the a-arm come down? If so the spring moved in the pocket and you need to re-index it.
Old Mar 7, 2007 | 08:40 AM
mlaudon's Avatar
Car: 89 Camaro Rs
Transmission: TH350
i had a jack under the control arm and jacked it up as i was doing it im pretty sure thats how you have to do it right..
Old Mar 7, 2007 | 08:41 PM
Car: 88 camaro
Engine: 355
Well if the spring didn't unseat itself, which it shouldn't if you had a jack under it while you changed out the strut the something is binding up and holding the car up. Like I said B4 struts have NO effect on ride height
Maybe take some pictures ?
Old Mar 7, 2007 | 08:45 PM
mlaudon's Avatar
Car: 89 Camaro Rs
Transmission: TH350
well i took a look today and i saw that the driver side spring in out a little and thanks for the help.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
87v6Bird
Jul 1, 2018 04:12 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
skinny z
Oct 5, 2015 06:23 PM
Vincent135
Sep 28, 2015 10:50 PM
