wheels and tires Q
Old Mar 20, 2007 | 05:12 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
wheels and tires Q
with my 385 coming out of the garage i know i will be needed tire upgrade. I am lookin at a pair of weld racing dralite wheels for my 89 firebird...
15x10 in 5 x 4.5/4.75 in bolt circle 4.5 backspace offsett is -25mm would these work for my car? also what would be a good set of mickey drag radial streets for them?
scott
Old Mar 20, 2007 | 06:26 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: wheels and tires Q
If you are doing a 10'' rim go with a 51/2 inch backspacing and use a 275-60-15 m/t drag radial. will look great.
Old Mar 20, 2007 | 06:40 PM
Car: 92 Camaro
Axle/Gears: S60 373
are you running the same setup? do you have a pic of this?
Old Mar 20, 2007 | 07:22 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you will be sticking out an inch if you use 4.5" backspacing.. use 5.5" backspacing and you are good.. and you want the 5x4.75 bolt circle.. and like said, a 275/60-15 will be good for a tire..
Old Mar 20, 2007 | 07:31 PM
Car: 92 Camaro
Axle/Gears: S60 373
thanksconsidering you also have a stroker and know what type of tire i need so 15 x 10 5.5 in backspace 4.75 bolt circle with a 275/60-15 will be good... awesome ill look it up..
Old Mar 20, 2007 | 09:46 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
I have 5 7/8 backspacing with holeshot wheels with 295-65-15 m/t drag radials. Thay take some work to fit under the car.
Old Mar 21, 2007 | 10:24 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
im actually trying to fit a 295 65.
any tips, or pics of the install.
im worried about rubbing the outer lip of the fender if any.
i can take care of the inside with my blue tip wrench.
Old Mar 22, 2007 | 09:27 PM
Car: 92 Camaro
Axle/Gears: S60 373
only mickey street radials i can find says max recommended rim width is 9.5"....am i missing something or would 15x10 still be ok??
Old Mar 23, 2007 | 06:30 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Stage 20 I rolled the upper lip and on the inside of the wheel well I started with the tourch and a hammer then my buddy grabed the air hammer it worked best and no fears of burrning the car or my house down lol. The air hammer you just keep going and try not to thin out the sheet metal to bad. The lower contoll arms will have to be changed to tubular control arms.
Old Mar 24, 2007 | 11:13 AM
Car: 92 Camaro
Axle/Gears: S60 373
can any1 answer that last Question?
Old Mar 24, 2007 | 12:07 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
what size tire, 275 60?
it may not be 100% recommended by the manufacturer, but a lot of folks run 275/60 on a 10" with good results.
Old Mar 24, 2007 | 04:42 PM
Car: 92 Camaro
Axle/Gears: S60 373
awesome thanks that is what i thought was the answer but wasnt sure
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
