Original IROC Valve Stems
Old Mar 29, 2007 | 12:39 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Checked the search with no results. On the Iroc-Z wheels, does the metal valve stems have a rubber or other type of washer on them? I need to pull all 4 and put them in another set of wheels I aquired and if sealing washers are needed, where can I get them? The wheels I bought are NIB and have no stem assy. Thanks, Badman
Old Mar 29, 2007 | 01:25 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Original IROC Valve Stems
When a tire shop mounts tires on wheels they replace the valve stems with new ones. Nothing special about the Stems on the IROC wheels, had mine replaced numberous times.
Old Mar 29, 2007 | 01:48 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Actually they are of metal construction and use a locknut to secure them to the wheel. I am trying to keep an OEM look on the car. So, if anyone knows where I can find the replacement washers for them, please reply.
Old Mar 29, 2007 | 05:50 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Well, you could get a tire inflation system, and paint the metal stems on those gold to match your rims. Other than that.... I've never seen a car with gold ones. Are they designed to throw away? Or be reused over and over?
Old Mar 29, 2007 | 11:15 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Those are aftermarket metal ones that you can buy at almost any auto parts store. I put lots of sets of those in that are almost exactly the same for people here at the walmart i work for.
gta90
Sep 15, 2015 04:00 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
