Tierod nuts rusted...Help
Old Mar 29, 2007 | 03:15 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
My tierod nut is rusted to the stud so stud just spins when I try to break loose. I've pb blasted it daily now for 3 days...still no luck.
Any help for a rookie ???
Old Mar 29, 2007 | 03:35 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Tierod nuts rusted...Help
I guess you are replaceing the outer tie rod end at the knuckle, if so use a hack saw and cut the nut. be careful to not damage the knuckle. Ball stud will be tough to try to cut so slice vertical down the side. may have to cut on opposite sides about 3/4 or so then use a chisel and a BFH to finish knocking off the nut.
Old Mar 29, 2007 | 04:34 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
usually you can use a pickle fork to wedge it enough to getit off with an impact gun
if not then i usually torch the nut and studif not then cut it with a sawzall steel cutting blade or do what bilms said yep
the problem you are having is common, the stud is not tight in the tapered hole
thats all
it happens all the time
do what you have to to get it off,
dont be nice to it
good luck
Old Mar 29, 2007 | 04:51 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Ive never seen one rusted enough to stand up to a impact gun
Did you try prying/applying pressure to it so the stud wont spin?
Old Mar 29, 2007 | 05:59 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Not yet..that seems like my next step before the sawzall..
Old Mar 29, 2007 | 06:21 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
yeah thats what you have to do to tighten them sometimes, Pry up on the tie rod, or even put some of the weight of the car on it, i bet itll crank of
timonator
Sep 30, 2015 12:52 PM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Fox118
Sep 12, 2015 09:29 PM
