Coilovers or Adjustable shock
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
im looking to find the best setup for the rear suspension. i have stock v6 springs with lakewood drag 50/50 and an airbag. when i launched my car the front left tire came up about a foot and a half and the other tire kinda stood down. im trying to prevent this twist and level out the suspension. what would you guys recommend. thanks alot
Re: Coilovers or Adjustable shock
Doesn't sound like a rear suspension issue... sounds more like the body needs stiffening. SFCs perhaps.
Car: 1987 IROC
the car has a 10 point cage with subframe connectors
Car: 82 Trans AM
Transmission: th350 turbo
wheelie bar perhaps.... sounds like your lifting a little hard when ya stomp on it. a wheelie bar will hold those front wheels down.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
damn this car must be badass lol i likeeee.
the twisting with subframes/ and a cage...idk if thats a suspension, u have the airbag already etc, wat do u have as far as the rear suspension goes.... aftermarket LCAs, panhard rod and i would look into a trac lock system with the shortened tubular torque arm. maybe even putting a stiffer spring with the one in the airbag to lessing the twist...maybe that could work
trac lock systems are made from BMR and maybe UMI and sphon
Car: 1987 IROC
I have lakewood drag shocks 50/50. Edelbrock Control arms. and a jegs panhard rod. and an airbag. i just orders some spohn coilovers double adjustable, ill see how they work
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
If that doesnt work, try the Spohn anti roll bar, it should fix it.
Car: 1987 IROC
The Coilovers work awesome and i also install the spohn anti roll bar. they work awesome together.
ill post up a photo soon to show you guys how it works
- a wheelie bar will do nothing to stop twist. The sole purpose of a wheelie bar is to unload the rear tires, thus lessening their ability to transfer weight/pick up the front end.A stiffer spring on one side will work, but the best way would be a stiffer anti-roll bar. A stiffer spring causes un-even reaction in the rear due to different amounts of "stored" energy. Not neccessarily noticable for drag racing, but the proper way is still a stiffer anti-roll. For drag racing I have also been know to preload the anti-roll. If you shorten the driver's link or lengthen the passenger's, the bar will be pre-loaded to help resist the twist.
Coil-overs w/o modifications to the mounting points can be dissasterous. - I believe the spohn kit addresses this though.
Car: 1987 IROC
they work awesome i went to the track yesterday. the car went 9.68 @139 with a 1.33 60ft on a footbrake
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I agree it sounds like you might need to check into the drag anti roll bar. I have no personal experience with them. But what you are describing sounds like that is what you need.
Car: 1987 IROC
ya i havent been on here in awhile. then i just got a reply. i do have the double adjustable rear coilovers and the anti roll bar. comes out real straight
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
pictures,pictures,pictures
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
