wheel alignment question
Old Apr 2, 2007 | 01:07 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
wont take long...my right front tire is slightly turned out of the wheel well (maybe 3 inches) when my left front tire is straight. Will this be fixed when i get an alignment or will i have to have the steering linkages adjusted?
a while back my car was clipped and the kmember bent and steering was all screwy...got the steering somewhat fixed and a new k member installed and the tires sit properly in the wells but with the exception stated above
Old Apr 2, 2007 | 01:22 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: wheel alignment question
The way it sounds the alignment should fix it as logn as all the damages parts were replaced. The linkage will be adjusted with the alignment.
Old Apr 3, 2007 | 12:07 AM
HPE's Avatar
HPE
Well based on your description it sounds now just link the new parts need alignment.If you still had a bent tierod the one tire would be turned inward not ouward while the other tire was straight-This is due to the steering arms on the spindles being located on the front side of the pivot point.
Amillionoh7
May 24, 2020 08:01 AM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
