Power Steering issue
Old Apr 3, 2007 | 05:51 PM
richardsruru's Avatar
Car: 1989 Camaro RS
Engine: 5.0 liter TBI
I have another issue. I just got my car running for the first time in about three years. When I got it, I noticed that there was no power steering fluid in the reservoir. I filled it up and now it grinds when I turn the wheel. What could be causing this? I looked at the fluid again after I ran the engine and there was some bubbles in the fluid as well after I ran it. Thanks in advance.
Old Apr 3, 2007 | 06:12 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Re: Power Steering issue
That is normal in this case. You will have to run the engine for a few minutes while turning the steering wheel back and fourth to bleed the system of air.
You will hear abnormal sounds until the air is removed.
Check for leaks when you are done.
Old Apr 3, 2007 | 08:54 PM
Car: 1989 Camaro RS
Thanks again. I will try that. Won't be until probably Thursday or Friday. I will let yall know.
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
