New Rear Needed Go Torque Arm or Ladder Bar
Old Apr 8, 2007 | 01:58 AM
birdsgonnafly's Avatar
Car: 87 T/A
Engine: none right now
Transmission: prob th350
Ok the big block swap is gettin ready to start and there is no way the stock rear end is going to hold up and i have the 12 bolt that is in the truck that im pulling the engine out of and i would like to use it under my car I relize that it needs to be narrowed have someone to help me on that and already checked into custom length axles but what im not sure of is what suspension to go with.
My first question is can my torque arm be used on on the 12 bolt? I know that i can transfer all the other brackets but im not sure about the torque arm
And if i cant use the torque arm my next step i guess would be ladder bars i would rather not do this but i can if i have to i would like this car to be mildly streetable and i dont have a ton of money to throw arround
Old Apr 8, 2007 | 03:07 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: New Rear Needed Go Torque Arm or Ladder Bar
you're better off buying a 12 bolt housing and axles made to fit these cars or a 9" rear end. Fabbing a torque arm setup is not going to be worth the time and money invested plus buying custom axles and having the housing narrowed.
Old Apr 8, 2007 | 03:23 AM
Car: 87 T/A
Like this one from Currie http://www.currieenterprises.com/ces...e.aspx?id=2369
then i could use my carrier right? then order a set of custom axles or are there a set of axles im not seeing on there site
Old Apr 8, 2007 | 10:07 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I install a 9" in my car, I installed ladder bars to eliminate the torque arm. The bad part is that the diff sits high in the chassis so the front ladder bar mounts are actually inside the car. I fabricated boxes on the floor to cover the front ladder bar mounts. It didn't matter for a race car.
A truck 12 bolt is not the same as a car 12 bolt. The pinion is different. The best and cheapest swap you can do is to buy a bolt in housing with axles in either a 12 bolt or 9". By the time you're doing modifying and fabricating a junkyard diff and modifying suspension to make it work, buying an aftermarket diff will be cheaper.
The moser link for the 12 bolt is just under $1000 and doesn't include axles. A 9" housing package is about the same price and does include axles.
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
