Strut plates
Old Apr 15, 2007 | 12:00 AM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
Strut plates
I just rebuilt my front end with new struts and springs and steering linkage, I took it for an alignment and apparently my car is missing strut plates according to the alignment guy. What exactly are these? The previous owner must have had these removed. Are they cheap and easy to find? Thanks.
Old Apr 15, 2007 | 05:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Strut plates
Originally Posted by Grim'91Z
apparently my car is missing strut plates . What exactly are these?
Strut retainers? I can't imagine that these would be missing, but...:
http://www.spohn.net/product.cfm?productid=1494
JamesC
Old Apr 15, 2007 | 04:43 PM
Grim'91Z's Avatar
Engine: L98 5.7L V8
Re: Strut plates
Can't be those, unless he was blind.
Old Apr 15, 2007 | 05:50 PM
JamesC's Avatar
Re: Strut plates
There are strut mounts and retainers. I can't imagine that either one could be missing. Look for yourself.
JamesC
Old Apr 15, 2007 | 11:21 PM
Grim'91Z's Avatar
Engine: L98 5.7L V8
Re: Strut plates
I know those are there, but the guy mentioned plates. I don't even know where plates would go (spindle mount or fender mount?). He said without them my struts would knock around and wear my tires out. The struts are a direct swap from the old ones and there was no plates on those (they were aftermarket as well, though). I did forget to put the plastic boots on the new ones, but those cant be what he is talking about.
Old Apr 16, 2007 | 05:24 AM
JamesC's Avatar
Re: Strut plates
Strut mounts are also called "bearing plates." The following link shows both plate and retainer. I have no idea what your mechanic is speaking of:
https://www.thirdgen.org/forums/susp...elp-quick.html
JamesC
Old Apr 16, 2007 | 09:18 PM
Grim'91Z's Avatar
Engine: L98 5.7L V8
Re: Strut plates
Interesting, well if I'm not missing anything then I should be fine. I just thought maybe the previous owner had those removed when he put on his Monroes.
Old Apr 16, 2007 | 09:44 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Re: Strut plates
Go to another alignment guy that knows what he's doing.
Old Apr 16, 2007 | 11:16 PM
HPE's Avatar
HPE
Re: Strut plates
If I lived near you I would volunteer my time to drive back to that shop with you and embarass the sh*t out of that idiot inpersonating an alignment tech.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
