Rear Coil Over Kit
Old Apr 17, 2007 | 11:07 AM
blown4now's Avatar
Rear Coil Over Kit
Does anyone know of a rear coil over kit for a 3rd gen? And more importantly, does anyone have pics of one does this way? I will be mini tubbing my car, and am looking to see if this has been done and where the coil overs were placed. Is there a kit for it? Or is it a custom only job? Thanks!
Old Apr 17, 2007 | 11:15 AM
HPE's Avatar
HPE
Re: Rear Coil Over Kit
Steve Spohn came out with a kit that has a top brace support for the chasiss side of the shock mount- this plate beefs up the shock mount to distribut the load of now carrying a springs and the rear chassis weight lying on them. Without that plate, the upper mount location will tear out of the chassis over time. http://www.spohn.net/category.cfm?categoryid=1183
Old Apr 17, 2007 | 12:01 PM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
would this be fine for a daily driver? im looking to redo my suspention on my 91. but reading on the forum not to may guys where in to the front having coil overs for a daily.
Old Apr 17, 2007 | 12:09 PM
blown4now's Avatar
Thanks a lot HPE. I knew I remembered seeing them somewhere, but was unsure of it. I'm sure I can tie in some extra support once everything is in place to increase the strength even further.
Old Apr 18, 2007 | 04:20 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
You can easily assmeble a coilcover kit yourself and save some money. I made my own reinforcement plates and measured up my shocks and bought coilovers the same size. With 150lbs spring and a few clevis mounts I was done and it saved me roughly 150.00 over buying them and I used the same parts. You just have to be resourceful.
Old Apr 20, 2007 | 02:28 PM
Shagwell's Avatar
Car: projects.......
You deffinitely must reinforce the mount area. You really need to find more than just the tin to tie too, which is very difficult since that's all there is back there. - Even with coil-overs you won't be able to do much in the line of mini-tubs as the rest of the suspension and the "frame rails" will be in the way.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Aug 26, 2015 08:17 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
