torque arm question
Old Apr 29, 2007 | 09:58 PM
183berlinetta's Avatar
torque arm question
i recently swapped the 5.0 with a 5.7. when putting the motor back in i put the torque arm (runs from the tail shaft to the rear end) back into the bracket. i was just wandering is the arm supposed to bolt into the bracket or just slide in and have some play. also the brackets "padding" looks to be worn. is it important to replace this bracket?
Old Apr 29, 2007 | 10:14 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Re: torque arm question
it "slips" into the rubber torque arm mount that is mounted to the tranny.
you can get a polyurethane one to replace it with. check energy suspension's website if you're interested.
brian
Old Apr 29, 2007 | 10:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The factory torque arm slides into the rubber mount. This allows the torque arm to slide forward and backward as the diff moves up and down. The amount of movement is very minimal. It's a factory design to reduce road noise transmitted from the diff through the torque arm. You can buy a new factory rubber bushing or an aftermarket poly bushing if yours is worn enough.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
