UMI sub frame install
Old May 6, 2007 | 08:38 AM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Ok this winter has bin good to my roc . I redid the whole suspension on the car less the A-arms and K-member . I have installed every thing on the car but the SFC's . My question is can I go ahead and weld my frame connecters in .Now that the car is lowered 1.25" and all parts are diffent, plus the pinion angel may not be right . I do not want to bolt the exhuast on and take it of the blocks . Also i do not want to have to put the car back up off the ground a week later . Do I need to wait for the suspension to settle .It will just be that much more fun to feel it all at once .
Parts list if any one was wondering
Tokico springs & HP's
UMI lca rod polly combo
UMI reloction brackets
UMI pan bar polly combo
UMI SFC's
Spohn wonder bar
Edelbrock ajustable torque arm
Energy sway bar polly mounts F+R,end links, tranny mount ,A-arm bushings
Hot part caster camber plates
Eaton posi ,Youkon 373 gears ,Youkon 28 spline axles
Ultumate rear cover
All new hardwhere
I spent over 200 hours with this, cleaning the under body with a wire wheel and under coating .Repainting all parts that went back on the car ,rearend A-arms ,sway bars ect . I want to drive ,thanks for the help every one .
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
