Which lcarb`s
Old May 4, 2007 | 08:58 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Which lcarb`s
I`ve searched and not found what I`m looking for.I`m actually more confused now than I was before.Weld in or bolt in?UMI,Spohn or whatever brand.I read and figured weld ins would be better,but after reading about dog trotting,improper mounting and trying to find a place around here to install them CORRECTLY at a decent price,I was thinking about the bolt ins and maybe have them welded in after instalation.Are the bolt ins reliable as far as being the correct way to install them and then welding?Thanks
Old May 4, 2007 | 09:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Which lcarb`s
oops
Last edited by //<86TA>\\; May 5, 2007 at 04:15 PM. Reason: o9h now i feel stupid <facesmack>
Old May 4, 2007 | 10:07 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Which lcarb`s
for the LCA relocation brackets, you just jack up the rear on a lift and lower one control arm and install the bracket then put the LCA in the lowest hole then weld in the bracket. That will keep the dog trotting to a minimum. Then you repeat for the other side, if it happens to be even slightly off it's not something you'd probably notice, although I run adjustable LCAs so they could be adjusted on an alignment rack if for some reason you had that issue which 99.99% of people i'm sure don't.
Old May 4, 2007 | 10:11 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: Which lcarb`s
Sorry,I`m refering to the lower control arm brackets.Not the sub frames.Even though your answer helped for when I`m ready to get subframes,I`m looking now to help lower 60" times and hook up better.I`m puttin some drag radials on layaway and would like to have the brackets on before iget them out in a few weeks.Thanks.
Old May 4, 2007 | 10:47 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: Which lcarb`s
see my post above.
Old May 5, 2007 | 12:20 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Which lcarb`s
Yea, bolt ins are bad because they can wallow out the bolt holes over time. It's just not a very permanent solution. Weld ins very rarely have any problems, i've only heard one time about someone saying it can happen - not a lot of evidence of it. Go for that and don't look back.
Old May 5, 2007 | 10:18 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Which lcarb`s
Whats nice about the bolt in are that you can install them yourself, then take the car to a welder and just have him welded on.
I installed UMI's bolt ins on my car, I'll have them welded on the 4th gen rear when I get it on my car.
Old May 5, 2007 | 10:56 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: Which lcarb`s
So krisb410,you havent had any problems out of the bolt ins?I was thinking about getting those and haveing them welded.How much do you drive the car?Any track time or hard driving?Any holes walowing out or anything?
Old May 6, 2007 | 08:41 AM
krisb410's Avatar
Re: Which lcarb`s
No problems from them yet, but I just installed them. I drive the car everyday, sometimes pretty hard. I am doing a 4th gen rear swap in the next couple of weeks, so I'll have them welded on that rear.
tylersb350
Fabrication
29
Jan 16, 2012 08:53 PM
godreject
Apr 24, 2008 10:02 AM
91_5.7_TPI
Mar 31, 2008 07:14 PM
V8Rumble
May 2, 2007 10:50 AM
black85camaro
Jul 5, 2004 05:55 PM
