homemade lcarb's
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
Re: homemade lcarb's
i know that the ones you buy drop the lca 2 and 3 inches. i measured across the center of the holes of the lca to get the radius of the holes in the bracket. i laid down a 4' x4' piece of partical board and made a line 19.25" long. put a nail on one end of the line and wraped masonry twine around it. then tied the other end of the string to a pencil at the other end. i kept the line tight and swung the radius downward to create my arc. then i drew my side view of the bracket on the wood and used calipers to measure the x and y cordinates then measured on the metal plate and center punched it then drilled away. there was a little more to it but i just made it short and sweet.
Car: 82 camaro sc
Engine: 355 SBC
thanks. i probably have about 2 hrs in them total. it will take me about an hour or so to line them up and weld them to the car tomorrow. i have $7 worth om materials....so thats not too bad.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I wish I had the experiance with a welder, then I too could make my own. I know how and have more then enough of the material needed just laying around and I have a welder in the house... I'm just not that good at welding.
Car: 82 camaro sc
Engine: 355 SBC
ive been welding for about a year. i didnt have anyone looking over my shoulder telling me what to do. i just went and bought a ton of wire and had at it on a bunch of scrap stuff. now i consider myself pretty good. im only as good as the welder itself is capable of doing. just practice and you will get it eventually.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Oh yeah....
Very nice. Hey, anyway you could post up some scematics for those of us more inclined at copying than engineering?
Max,
Max,
Anyone got dims for these?
Car: 1991 Camaro Z28
Engine: 5.0 V8 TPI
It seems like it is really hard to find any sort of suspension dimension on here. Im at school 300 miles away from my car and i want to make a set of these but i need dimensions
so if you got em i could use them. thanks.
so if you got em i could use them. thanks. Joined: Oct 2009
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
How about a template? $60 bucks is a lot of money for some simple mild steel with holes.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Because it would save me time trying to locate the holes. Not trying to offend anyone, I just don't need them to be pretty and powdercoated and all.
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
, I'm pro do-it-yourself if you can.However, $60 for a design, cut, assembled, welded, painted, with hardware included is a very reasonable price.
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Wow!! That'll help a lot! Thanks a lot! and I understand it being a reasonable price for what's included, but from my stand point (being: doesn't need to look pretty, and I have access to plenty of hardware), It is not worth spending as much money on them as what some people want for them. But to each their own, I can completely understand why some do prefer to buy nice brand new name brand parts. If my car was a show car or an autocross car or something, I might dig a little deeper in my wallet.
I personally do like "doing it myself" though, It makes me feel like I've accomplished more. and being a college kid, I don't have all the money in the world...
Thanks again for that template!!
Can you tell me the exact measurement shown by the crude arrow in this picture? I'm going to use 3/16" steel for mine, I imagine it'll be easier to get my hands on. but this measurement is really more important than any.
Thanks!
Thanks!
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
At the top, not including the additional thickness of 5/32 times 2 comes out to be 2 3/4".
With the extra 5/32 x 2 added as shown in between where your arrow sits, it comes out to be... ~ 2-7/16.
Maybe this pic will help lol
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
Not sure what you guys are using your cars for but if your going through the trouble of making your own then you might want to improve on a plain design. If your car is lowered and you want to drag race it is possible to need even more holes! Places like trz use 7holes in there rearend builds
My car is honestly a daily driver that I want lowered, but I just don't want to sacrifice too much cash or traction. I do some hot rodding here and there, but I don't need to do anything too crazy.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Car: 86 camaro sport coupe
Engine: 350 ci. alluminum headed sbc
Transmission: TH350 w/9" 3800 conv.
Axle/Gears: 31 spline strange /4.11
my time is worth more than $59.00 (Hawksthirdgenparts.com).
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Car: 86 Trans Am
he is just kinda saying that its cheaper to just buy them. And founders sells these, with all new hardware for 47 bux, its a no brainer.
but if you need a project to keep you busy for a few hours, and you have toe tools, go for it.
agreed... If it takes you 3 hours to make a set then divide the cost of what they sell for by 3 and add the cost of materials...this is what it cost you per hour (paying your self) its simple math it always comes down to which you do have more of time or money... or you just lack fabrication skills...
Flash84Z28
Nov 27, 2001 05:54 PM
SlowCamaro88SC
Nov 17, 2001 07:13 PM
theformula
Oct 17, 2000 09:42 AM
