Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Steering wheel
Old Aug 6, 2011 | 10:16 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Steering wheel
I want to put a new steering wheel on my firebird 1987 and i was wondering if anyone could tell me how to take the stock one off.
Old Aug 6, 2011 | 10:21 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Steering wheel
You'll have to get a steering wheel puller from Autozone/O'Riellys/wherever.
Pull the horn button off, unplug any horn wires in there, pull the big nut out of the center then use the puller to get the steering wheel off. It is basically a press-fit & no way to get it off without a puller.
Old Aug 8, 2011 | 12:54 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: Steering wheel
harmonic balancer puller works to
Old Aug 9, 2011 | 07:23 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Steering wheel
The best and fastest way to remove the big nut under the horn button, is to use a
4-way tire lug wrench. One of them will fit perfectly and the wrench will give you plenty of torque to quickly spin it off.
Old Jan 16, 2012 | 11:57 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Steering wheel
here is one that i want for my firebird MOMO Steering Wheel GTR2
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
