Front suspension and steering box
Old May 21, 2007 | 08:59 AM
Gm Jray's Avatar
Car: 1988 Camaro Iroc-z
Engine: 383 Stroker Built
Transmission: 700r4 built
Axle/Gears: 373's limited 28 spline
I have searched and nothing really came with the guidelines I needed.
I'm still new and learning
I'm doing a large swap from a 88 Iroc into a 92 RS
What I'm swapping is the front suspension, everything was brand new
Will Everything match up right I've been told all the arms and all are the same,
I want to swap the steering box and column, A lot better ratio and the rs just sucks.
Now what will this include? Will it be easy bolt up and a lot of aligning.Will i need a different pump with more preasure?
Old May 21, 2007 | 10:24 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Front suspension and steering box
The only difference in third gen parts from 82 to 92 is cosmetics and updates. They're all interchangeable.
Old Apr 20, 2008 | 03:03 AM
lonesomecrow's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
I recently got a rebuilt steering box from the local pick 'n pull from an IROC just cuz I knew they handle way better than RS's. I know it was rebuilt/replaced because it looks cleaner that most of the components still on the car including the pitman arm. Tonight I did dome research and found out I got the highly desirable XH box, so I went to look at my car that has the stock box AFAIK and came to find out that it has the same one in it, except that it might not be the XH but the WS and I know this because I have 16 inch IROC replicas and they rub a lot. So you might already have the quick ratio box but you would need to take a look on the numbers that are on top of the box itself!
Old Apr 20, 2008 | 11:55 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Not quite true! 1982 cars have a few unique parts. The lower control arms are different, the k member is different to take the different control arms, the sway bar mount is different (why some companies wonder bar do not fit 82's) and I can't remember the fourth issue. Also as i recall. The upper spherical mounts are different. I think they go 82 to 86 are the same and 87 to 92 are the same.
Your 88 to 92 won't have any issues.
Frozer!!!
Jan 19, 2024 04:55 PM
Amillionoh7
May 24, 2020 08:01 AM
Vintageracer
Jan 10, 2020 05:33 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
