next mod, chassis or rear?
Old May 26, 2007 | 05:51 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i know this isnt totally suspension or chassis related but my focus is handling so i thought this would be a good place to ask
my next planned upgrades were 3.42 gears with a posi(like an eaton unit) and stornger axles(28 spline), jegster torque arm, and lca relocation brackets. i can not afford to do all these at once though. which would give me the most benefit?
also i have subframe connectors sitting in my basement, i tried to install them once but found that my stock y pipe is in the way. i was thinnking i could make a custom true dual system that dumps before the axle and install my subframe conenctors, but id need the jegster torque arm in order to run an x pipe with good clearance.
im just not sure what to do first, thanks!
Old May 26, 2007 | 08:02 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: next mod, chassis or rear?
I think that getting the SFCs in would be a good idea; but what brand are they? Why don't you sell them and order a set that'll fit the exhaust?
Old May 26, 2007 | 11:47 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
SFC's are the best and first thing you should do. They will prevent your car from twisting itself up if your engine is making any power and your able to get it to the ground. All the other stuff you've got listed is gonna give you better traction so do the SFC'c first. After I did mine I noticed a huge difference in the handling and feel of my car.
Old May 27, 2007 | 05:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Like the guys mentioned, install the SFC's. On a side note: I have no personal experience with true duals, but given the ground-clearance issues with our cars, I'd think that they might be more trouble than they're worth
JamesC
Old May 27, 2007 | 12:26 PM
MaNiAk86's Avatar
Car: 1983 trans am
the sfc's are the jegster bolt in units. they will fit with the stock y pipe, but the y pipe has to be loosened or moved out of the way to bolt them up. then replaced.
im not running rear seats in my car , so im going to do some floor modification to fit mufflers where the rear seat used to be. i have access to a welder and lift, so i figured id give it a shot. i just hate how mustangs sound so good with their damn true duals. and i want my car to sound different than every other f body out there. and if the dual exhaust doesnt have enough clearance ill go back to a single 3", it will be a learning experiance im sure.
either way ill get my sfc's in.
Old May 27, 2007 | 01:46 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
You don't want to run the bolt-ins for any more than you have to. The bolts holes wear bigger and the SFCs get loose. Weld them in or get some Spohns or the like.
Old May 27, 2007 | 05:50 PM
MaNiAk86's Avatar
Car: 1983 trans am
i was going to bolt them in then weld them at a buddy's house. ill grind the paint off the welding surfaces before i bolt em up.
Old May 27, 2007 | 08:56 PM
Car: 88 camaro
Engine: 355
That's the right way to do it!
Old May 27, 2007 | 11:47 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have the jegster torque arm, bolt in subframes that we welded right away along with true duals. Feel free to check it out sometime or whatever. The subframes should fit right in, I believe on another car that came into my old buddies shop we just put a jack on the subframes to wedge them around the y-pipe momentarily.
Old May 28, 2007 | 04:09 PM
MaNiAk86's Avatar
Car: 1983 trans am
id love to see your setup and we live in the same area kinda. do u ever race up at GLD? i hope to see ur car in person some time but ive never seen u up there.
where can i find pics of your exhuast setup? are u running an x pipe?
Old May 28, 2007 | 05:56 PM
MaNiAk86's Avatar
Car: 1983 trans am
has anybody used the UMI bolt in relocation brackets? are they strong enough for tough use like auto-x, could i bolt them and weld them?
Old May 28, 2007 | 06:25 PM
Demon355's Avatar
UMI relo-brackets are more than enough for Auto-X. I have a set waiting to go on my new rear and one of my buddies is currently using them and they work perfectly. I recommend them to anyone. If you do buy the bolt on set, make sure you get them welded up for added strength.
Old May 28, 2007 | 06:27 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
That reminds me...I need to have mine installed when I get the SFCs.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
