Traction problems
Old May 29, 2007 | 11:28 AM
zachsdad's Avatar
Traction problems
I installed home made subframe connectors (they look like CE's) And relocation brakets. The car is real stiff and will fly around corners. I still have a lot of wheel spin off the line.
Dose everyone use slicks at the track?
The motor is stock 305, 373 posi and the converter is 600 over stock.
Old May 29, 2007 | 07:03 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: Traction problems
[QUOTE=zachsdad;3355917]
No. but they probably dont run hard as nails, in it for the long mileage tires on them either.
buy stickier tires..
Old May 29, 2007 | 07:09 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
sfc's wont help traction much, it helps wight transfer but if your rear suspension isnt built for the added stress you will spin more. invest in some LCA relocators and a trans tunnel mount torque arm. you will feel a huge difference.
my stock 305 can barely spin em anymore, but that with stock 3.23 gears. im goin up to 3.42's and hopefully ill b able to spin em without a braketorque.
Old May 30, 2007 | 07:52 AM
zachsdad's Avatar
I dont want to invest in a torque arm, since I will be back halfing the car soon. I already have LCA relocators I made them when I did the subframe connectors. I found some 10.5 slicks and weld wheels for $350. I am going to buy them this weekend.
Old May 30, 2007 | 03:52 PM
MaNiAk86's Avatar
Car: 1983 trans am
sounds like a plan. slicks do the best smokey burnouts
Old Jun 1, 2007 | 10:35 AM
Shagwell's Avatar
Car: projects.......
3.42's may spin easier out of the hole, as if traction reamians the same you're not bring up the wheel speed as fast. Secondly why would you want a loss in traction?
As for the original post, if you're planning on back-halfing the car then just do it. Otherwise, plan on spending some more time/money to make what you have hook.
My car runs high 11's on street tires and it'll hook in the rain all on the factory type suspension.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
