questions about lca bushing types
Old May 29, 2007 | 07:53 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i have heard from many different sources the poly/poly on the lca is not good and causes suspension bind during corners. currently i have lakewood lca's with poly/poly and i love how my car handles. but if swapping bushings will make a difference then i am very willing to do it.
heres my questions, which end should the poly side be on?
do i have to rod end the other end?
can i use a solid aluminum spacer like the comp. engineering (jegs pn 247-3165)? or do they have to be rubber?
thanks-
Old May 29, 2007 | 08:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: questions about lca bushing types
if you have a poly/spherical piece, the poly goes on the body to absord road noise, and the spherical end goes on the axle. the ones you buy have aluminum spacers on the rod end side to make up the space.
Old May 29, 2007 | 08:26 PM
MaNiAk86's Avatar
Car: 1983 trans am
no they are solid aluminum bushings that will fit in my current control arms, they are not rod ended
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 25, 2015 07:34 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 11, 2015 02:59 PM
NBrehm
Aug 5, 2015 07:57 PM
