Tubular K-Member Options
Car: 1982 Indy 500 Pace Car Replica
Engine: Stroked 350 (385ci) TPIS Mini-Ram
Transmission: 6-speed
Axle/Gears: Stock w/Disks and 4.10's
I am looking to get a tubular K-Member for my 3rd Gen. I plan to autox and drive my car on the street. I have been told not to go with a tubular K-member on a street driven car because of the possibility of cracking from hitting pot holes and other obsticals. So I am wondering if I go thru the expence of getting a full tubular front end or just get coil overs and tubular a-arms.
Thanks in advance.
Thanks in advance.
Car: 82z28
Engine: 406
Transmission: th350
Re: Tubular K-Member Options
Call UMI, I dont think they have theire finalized yet, but some interest may spur things along. They make a "road race' version for fourth gens and in the past ryan has stated he planned on doing one for us third genners
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I've never heard that. I plan on getting a tubular k-member and a-arms when I get to do an LS1 swap. Hopefully UMI will have theirs with the LS1 conversion mounts then.
Tubular is fine as long as it's built properly. - Most aftermarket units are designed more for straight line use, thus aren't really strong enough for continual side loading.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Just a FYI, all the available tubular subframes and A-arms on the market for 3rd gen's do NOT change the geometry of the front suspension and therefore will not do anything for handling. They also only remove a small amount of weight.
You can save the same amount of weight by going to a smaller battery, or swapping on some aluminum parts on your engine.
This should be the last modification you should consider for auto-x.
i'm interested too... the delay time and overall reponse on this site has made me lean towards either bmr or aje. i already had a pa chromoly, worked great for me. just sold it on ebay actually. it was coilover, however i'd like to try something new. i called umi. no plans for one anytime soon so that means maybe next year if were lucky. i'll order another pa at that rate.
I didn't say we had no plans for a 82-92 K-Member. My exact words were we have been working on it for sometime now but it is not completed yet and we hop to have it released in the near future. This isn't item you want to rush.
Thank you,
Ryan
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I like my AJE kmember a lot, but I would weld on extra gussets if you're going to road race it, but by then it won't save much weight. So unless you're running exotic exhaust configs, money could be spent elsewhere.
Ok, so pardon my ignorance for asking, but if a tubular k-member does absolutely NOTHING for handling, then what is the goal of slending so much money on something like this. I have been looking onto getting the Spohn TKM but now I am having doubts. I was under the assumption that it would help handling a lot along with all all of the other spohn components. ( planned to do a complete Spohn makeover underieth the car). Is this a good idea or should I now consider somebody else that might be cheaper. I was under the impression that spohn was some high quality ****. Maybe I was wrong.
Weight and room for mods. I know a 4th gen guy that used one to put in a 3400 boosted FWD motor and was able to lower the engine another 1.5-2". If you wanted to use true duals or huge down/y pipes it makes life a little easier.
Are you going to be looking at side loading considerations in the K-member? I also want to end up doing some auto-x with my 89' TA and was looking into K-members both for extra space for exhaust and for better suspension response...
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
im getting a tubuler k-member for the fact that it will make my bbc swap a little easier especially on trying to run the exhaust. from what i hear weight is not a reason to buy a tubular k.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
UMI also has awesome customer service
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have driven 2000 miles on my PA racing one I got off ebay and it looks great. I was able to install my 2210 long tubes in about 30 miuntes. Also spark plug changes take me about 45 now!!
Oh and yes it is a 100% street car. I also have tubeular A-arms. go to my CD site if you wanna see what my "street" setup looks like
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
Also my cars frame is Dead stright.
IROC4LIFE
Engine: 406 Roller
I haven't started putting mine in yet. I am kinda dreading to. I thought maybe I will get a good one. I also thought I would get my K member on time and not have to wait like everyone else. I was wrong about that one. We will see.
We make that K-member (we have them in stock) and we also have new 2"drop spindles coming for the 3rd and 4th gen. We will have our prototypes at the NMCA race in Memphis this weekend. We will start shipping spindles Nov.5. In the near future we will be concentrating on our new rear suspension products. Look forward to spending some time on this site.
Thanks, Mark
http://www.racecraft.com
Thanks, Mark
Engine: LS3
That looks a lot like my K-member. hard to really see it since it is only 1 pic and it is black, but I have a kinda old PA racing member. Has worked great after 3000 miles of hard street use.
Happy to see more companies making parts for these cars!
We will update our camaro section with more picks after we get back from Memphis this weekend. It looks like PA's because we used to private label for them several years ago. Our current K-member is similar, but different mainly in the engine mount and rear buckets.
Mark
Mark
Engine: LS3
Nice. looking forward to seeing the parts.
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Mark
Mark
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Mark
Mark
Engine: LS3
Yeah, if you guys REALLY wanna stay on the cutting edge and get a market that no other company has, maybe an adj. TQ arm that mounts to a tranny x-member that has clearance for dual pipes. I know of 3 people off the top of my head that would by one and throw away their spohn piece today.
Just a thought.
Just a thought.
gixxer92
May 18, 2017 11:20 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
- but it does allow a lot more access around the engine.
