special tools needed?
Old Jun 17, 2007 | 02:41 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i just bought a cheap front suspension kit.
tie rods
center link
idle arm
sway bar links
any special tools that I NEED?
or can i get away with sockets, wrenches, rubber mallets etc....
looks like just pins, 10 mm bolts and nuts and grease holding all this together but enlighten me please
Old Jun 17, 2007 | 08:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: special tools needed?
Basic should do you fine. A torque wrench will come in handy. You may need a swivel for your socket when you go to mess with the idler arm.
Old Jun 17, 2007 | 01:50 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
It can be nice to have a tie rod fork or puller depending on how well they are stuck in there. If you are replacing them though, you will be alright beating the crap out of it. Don't forget to grease everything up really well, if the tie rods and idler arm have zurk fittings lube them at least every 6 months.
Old Jun 17, 2007 | 05:58 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Go to Autozone and get a pickel fork and a BFH (big f'in hammer) to go with it. The fork is $10 and you can keep it or return it after your done (if you do the rent a tool) and for the hammer, 3lbs. did the trick for me (also $10 fom AZ). This is cheap stuff and will save you a lot of time. I could not get my idler arm off without the fork and hammer. A torque wrench is also a requirement when working with the suspension and steering so you can torque everything to spec.
Dkelz313
Apr 7, 2016 10:38 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
