Is Torque Arm Bent? (pics)
Old Jun 19, 2007 | 02:32 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Well, while driving I started hearing some clunking from near the trans tail shaft (T5), looked and the torque arm had ripped out of the stock bushings. I bought a poly bushing and I was installing it today and in order for it to fit into the clam shell, the torque arm only goes about 1/2 way at most into the bushing. This doesn't seem right at all to me, so I took off the torque arm and took some pics, is it supposed to be perfectly straight stock? If so, can I pound it back straight or will this kill the arm's integrity?
Attached Thumbnails Is Torque Arm Bent? (pics)-tarm1.jpg   Is Torque Arm Bent? (pics)-tarm2.jpg   Is Torque Arm Bent? (pics)-tarm3.jpg
Old Jun 19, 2007 | 07:51 PM
BronYrAur's Avatar
Engine: 305 TBI
Re: Is Torque Arm Bent? (pics)
TTT i'm trying to reinstall this thing now
Old Jun 20, 2007 | 03:05 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
the torque arm usually is straight.. so yours would be slightly bent.. not a bad time to upgrade..
Old Jun 20, 2007 | 04:14 PM
BronYrAur's Avatar
Engine: 305 TBI
Thanks for the reply, I'm going to try to pound it back into shape, if it still won't work then I'll bite the bullet and go aftermarket. Right now, I had to order a new inner bracket because the attached bolt broke loose and spins freely, as well as the entire bracket being bent up.
Old Jun 21, 2007 | 08:22 AM
Shagwell's Avatar
Car: projects.......
definitely looks bent. New bushing and bracket for an arm that's bent? Even if you beat it back it has already lost its structural integrity. I wouldn't spend any money trying to fix a factory arm.
Old Jun 21, 2007 | 10:40 AM
BronYrAur's Avatar
Engine: 305 TBI
Yeah, you're probably right, I need the new bracket anyways though, so now I'm looking into just buying another stock arm. Are the automatic arms the same as the manual trans arms? As long as the lips are facing the same direction I figure they're the same part
Old Jun 21, 2007 | 06:39 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
all the tourqe arms are the same exept that some have the lips facing out rather than in. IE this http://www.spohn.net/productimages/7-1609_big.JPG Or this http://www.spohn.net/productimages/7-1611_big.JPG
Old Jun 21, 2007 | 08:21 PM
BronYrAur's Avatar
Engine: 305 TBI
Thanks for the info, I was pretty sure they were the same, but wanted to make sure. I'll be getting one soon
morrow
Jan 13, 2024 12:29 PM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
TheExaminer
Sep 6, 2015 11:40 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
