Broken spring and lowering by coil cutting suggestions please.
Old Jul 1, 2007 | 11:10 PM
mrogers's Avatar
Car: '87 Camaro
Engine: 4.3L V6
Axle/Gears: 3.08
I took apart my front suspension yesterday and got both springs out. The driver side spring was broken a half a coil around on the bottom. I didn't notice any problem I guess because the broken end was still sitting on the mount in its normal position. My question is, should I replace the spring because it is going to fail further up the spring later, or is it okay to use because
I'm also looking to lower the car about 2 inches. I wanted to know how much to cut off. I was going to try a half coil (ironically, I guess I'd only half to cut one of them now) but I don't want to have to do it twice and was just looking for a suggestion.
Old Jul 2, 2007 | 04:41 AM
CrazyHawaiian's Avatar
Car: too many ...
Re: Broken spring and lowering by coil cutting suggestions please.
I think the fact that the spring was broken is a sign of fatigue. The spring will probably break again. So I would say use them to practice cutting good, and buy a new set to cut to run in the car (if thats how you want to do it).
Old Jul 3, 2007 | 08:49 AM
Stephen's Avatar
Car: 87 GTA
Half coil up front, 3/4 in the rear worked good, and I autocrossed this car, with no ill effects.
My OLD home page
I can't even access that page to update &edit anymore. Geocities won't even answer me about accessing it again.
Old Jul 3, 2007 | 12:06 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
If you are going to trim the spring, you should know that you trim from the TOP!! Not the bottom. I trimmed my rears with no problems at all.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
TA8487
Aug 11, 2015 09:02 PM
