4th gen wheels on 3rd gen cars
Old Jul 5, 2007 | 09:25 AM
89jim's Avatar
Can 4th gen wheels be bolted right on 3rd gen cars. If not what can be purchased that is a direct bolt on? I have found some posts that refer to spacers,how do they work with factory studs? Won't the studs be to short?
Old Jul 5, 2007 | 09:30 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: 4th gen wheels on 3rd gen cars
the front will need 2"adapters,these fit onto your rotor and get bolted on with lug nuts and then your wheel gets bolted onto the adapter.
the rear can be done in the same way or you can put a 4th gen rear end in your car.
Old Jul 5, 2007 | 09:52 AM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
I have put a 4th gen rear in my car from Moser. I had to go with a +42 offset with 7 inch rims, so they do not stick out past my wheel wells and on the front I went with 2 inch spacers. The switch to 4th gen style rims is hard to get use to if you are use to the closed style rim. It is beginning to grow on me , but I am still not sure
Old Jul 5, 2007 | 12:27 PM
ssean92's Avatar
Car: sold
these are the only ones that look good on 3rd
Old Jul 5, 2007 | 02:57 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I just did this swap 1 to 2 months ago, do a search to find my post.
1992rs/ss
Jan 31, 2025 05:10 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
AkDrifted
Aug 17, 2015 07:45 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
