Is a 4th gen rear end swap a bolt in?
Old Jul 5, 2007 | 12:35 PM
89jim's Avatar
Can the rear out of a 4th gen be bolted right in a
3rd gen car? If not what mods are needed?
Old Jul 5, 2007 | 02:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Is a 4th gen rear end swap a bolt in?
if you have a disc brake car, the rear should be a direct bolt in. Even drum brake rear end thirdgens should be a direct bolt in, but you'll have to check the rear brake line connection from the car's body to the rear end. i do believe its the same as the disc brake 3rd gens.
for drum cars, you'll need a disc brake proportioning valve. some ppl tho have used the drum one without problems...but i'd do the disc brake one anyway just to be safe
Old Jul 5, 2007 | 03:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
and 4th gen rears are wider
i was going to opt for a posi drum 4th gen rear for my 82 so i could dump the 2.73 open junk but too many things are different for my taste
so im going to stick with a 3.42 or 3.73 third gen rear
Old Jul 5, 2007 | 04:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
other than being wider, everything else will bolt up including torque arm, shocks and springs, and lower control arms. can reuse thirdgen sway bar.
Old Jul 5, 2007 | 04:42 PM
89jim's Avatar
How much wider? What gears come in them? Are all 4 gen Tran Am rears posi?
Old Jul 5, 2007 | 05:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
check this thread i made about my swap... pics inside.
https://www.thirdgen.org/forums/faq-...-gen-rear.html
basically they all should be posi if its a trans am. generally its 3.23's or 3.42's gears. some had a 2.73s but trans ams should have one of the higher gears
EDIT. forgot that E brake cables will be needed for 98+ ls1 car rear ends. thirdgen style dont work nor do the LS1 4th gen style
Old Jul 5, 2007 | 06:33 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Have a question concerning 4th Gen rear axle assy:
Why can't you take the center section from a 4th gen rear and install it in a 3rd gen axle housing using 3rd gen 28 spline axle shafts??? Since all 10-bolt are the same internallly. Anyone want to give the pro & con why it cannot be done??
Old Jul 5, 2007 | 07:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
it can be, if its the later 3rd gen 10 bolt that has 28 spline axles.
center section is the same. so you can take out a 4th gen posi and gears, and place it into a thirdgen rear with thirdgen axles.
i never heard it wasnt the same
Old Jul 5, 2007 | 07:06 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Drum brake rear ends are also a direct bolt in I just swapped a 4th gen rear into my 83 Z with rear drums. My stock lines hooked right up to the 4th gen calipers. The problem you will run into though is the brake lines have a 90 degree bend at the end so you will have to bend them so you can connect them to the caliper lines.
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
