rear end noise.....help. 1989 TA
Old Jul 6, 2007 | 04:43 PM
jdaniel's Avatar
I put the Eibach 2" lowering springs, all Spohn tubular bars underneath, Mosar 12 bolt, LCA brackets, Spohn panhard, frame connectors and roll cage on my 1989 TA. It had a terrible rear end noise EXCEPT when you let off the gas. I moved the pinion angle up and down....no help. It was terrible. I finally put the original 9 bolt and factory torque arm back in. The noise is still there, not nearly as loud, but still pretty loud. I cut the front off the factory tourqe arm and moved it up 3/4 inch and rewelded it...no good. Moved it down 3/4 inch...no good. What gives? What else could it possibly be? The factory stuff was completely quiet before I did all this. I have a lift here at work and I've had the car in the air probably 20 times trying to find the problem with no luck. I called Spohn today and they ddidn't seem to have an answer.
Any ideas?? Jimmy at jddani@aol.com
Also, the car runs 11.90s with cold a/c and all power options and is for sale with BOTH rear ends. Mosar 4:11 12 bolt complete bolt in and the factory 9 bolt 3:73. Super, super car......13,500.00
Old Jul 9, 2007 | 10:21 AM
jdaniel's Avatar
Re: rear end noise.....help. 1989 TA
help
Old May 28, 2008 | 02:54 PM
jdaniel's Avatar
I have still not solved my problem. When you are accelerating with either rear end, it's very loud (sounds like a pinion bearing) but when you let off the gas, it goes quiet. You barely have to touch the gas and it starts back up. Does anybody have ANY ideas?
Old May 28, 2008 | 05:28 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
If it didnt have the problem before you started, it has to be something you did. Maybe something is loose?
Old May 28, 2008 | 05:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its the rear, they are aftermarket performance gears and they make noise, im sure if you rear the paperwork included with the moser rear it will tell you that, mine did. Mine make the worse noise when letting off the gas decelerating, annoying, but not that bad
Old May 28, 2008 | 10:40 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Thats strange, your absolutely positive that its coming from the rear? Maybe the driveshaft or brakes? Did you mess with the yokes?
Old May 29, 2008 | 09:19 AM
jdaniel's Avatar
I lowered it, put the tubular bars on and added the mosar rearend all at the same time. I've had it on my rack countless times and checked and rechecked everything I can think of. Finally I gave up and put the stock 9 bolt back in and the noise was still there! Again, I've checked everything I can think of to check. I've had new u joints and had the shaft balanced. As soon as you let off the gas the noise is gone. When you get back on the gas (even just a little) it's whining like MAD. It has to be related to lowering it because swapping the rears didn't make a difference. What else could it be? THANKS for all the help!!
Old May 29, 2008 | 11:04 AM
jminton's Avatar
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
transmission?
Old May 29, 2008 | 01:40 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
What kind of transmission do you have?
My car does the same thing it whines when your on the gas and it silent when you let off
Old May 29, 2008 | 01:50 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
maybe its the sway bar end links..
Old May 29, 2008 | 01:51 PM
jdaniel's Avatar
Mine has a 700R4 but it was totally quiet before I messed with it. Thats what keeps puzzling me. I'm just missing something.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
