Solid tie rod, no ends
Old Jul 9, 2007 | 01:09 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Has anyone ever done a solid centerlink to get rid of the tie rod ends? I've seen this setup on 4x4 trucks recently and it looks to be way more solid than using the tie rods. It would eliminate bump steer and would also get rid of the idler arm.
So the left/right spindle would be connected with a solid bar with adjustable spherical bearings. Then the steering box would have a rod that connects straight to the new solid center link. I think its called a drag link?
http://www.4x4wire.com/toyota/tech/dana44/steering/
Old Jul 9, 2007 | 02:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Solid tie rod, no ends
It doesn't work with independent suspension. A single tie rod system is used on solid axles only. Bump steering would be worse with independent suspension.
Old Jul 9, 2007 | 04:47 PM
Blue1989RS's Avatar
Car: 1989 RS
I guess I could have thought about that a little more before posting. Sorry for the dumb thread. I've had a long boring day at work. Sometimes we all get a little
Ghettobird52
Apr 21, 2020 08:44 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
