Strut and Mount Question
Old Jul 12, 2007 | 04:51 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Just finished rebuilding my front end on my 85 Iroc-Z. I used all new Moog and Bilstien parts. Now I cannot get the plastic strut cover on that protects the top of the strut bearing mount. Either the bearing housing is a different diameter or the strut shaft is too tall, or both. Anyone had this problem? Badman
Old Jul 12, 2007 | 05:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Strut and Mount Question
Yeah. I think the diameter of the mount is a bit smaller. I had to force mine in a bit.
JamesC
Old Jul 12, 2007 | 05:48 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Just sent you a PM. Thanks for the answer. I am tearing the edges up trying to get them in. Maybe time for some new ones, hope I can get them in without destroying them too! Badman
Old Jul 12, 2007 | 08:39 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
I had the same problem. The only way I got them to fit was to take a sharp box cutter and cut a small pie wedge out from the point out to the outer edge. It fits perfect now and you can't tell because it overlaps itself a little bit.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
