Strut Tower Bar?
Old Jul 23, 2007 | 08:59 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Strut Tower Bar?
I purchased the edelbrock STB for a 92 TBI motor and it doesn't even come close to fitting the car. im sending that POS back to edelbrock. What are my options for other STB's? I've tried finding some but all i could find was a BMR that looks to be designed for TPI.
Old Jul 23, 2007 | 09:13 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Strut Tower Bar?
In my opinion STB's are a waste of money, there is absolutely no way that there is enough flex in the strut towers to effect handling. You have to remember that force from cornering is acting through a very tall strut so even if you have 2000 lb's of force at the wheel you are only looking at 250 lb or so at the strut mount. You'll get about 10 times as much movement from the rubber mounts as you'll get from the towers themselfs.
On top of that they are a pain to work around.
Old Jul 23, 2007 | 11:45 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
My edelbrock STB fit just fine, check out my vbgarage pic. I agree on the stock rubber upper strut mounts allow to much flex themselves. But I got the solid mounts from spohn. I will say that I really didn't notice any difference after I put the STB on, but I got it for free by trading some parts I didn't need anymore, and I would have tossed the parts anyways.
Old Jul 24, 2007 | 07:46 AM
Stephen's Avatar
Car: 87 GTA
My Edelbrock STB fit fine. What was wrong with the fit on yours? My first guess, would be you had a TPI STB.
Old Jul 24, 2007 | 08:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if its soooo hard to flex, why can i visually see it on cars?
its a couple sheets of stamped sheetmetal tack welded together. it flexes.
if you want an overly dramatic infomertial like example, take the hood off, put a piece of string tight between the tires, and go corner in a parking lot.
or i could just floor my car from a stop.. that'll show you EVERYWHERE the car flexes.. LOL.
Old Jul 24, 2007 | 09:47 AM
92MaroRS's Avatar
to make the main brace miss the master cyl, the rear brace wouldn't even come close to being able to drill holes in the lip on the firewall. it is deffinantly not a TPI STB
Old Jul 24, 2007 | 10:56 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
The edelbrock stb's have been notorious for poor fit. I have one for tpi and it was a pita to get the fitment right. Unlike the other comments I did feel a difference in the front end even during low speed turning. I don't feel as much flex when pulling into parking spaces and on bad road we have around here.
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
