spring swap decisions
Old Jul 10, 2007 | 08:35 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
currently i have eibach prokit springs on my 86. i kept the stock iroc springs. now i am looking at an 84 formula to buy. i was planning on swapping all my camaro suspension mods(lca's, adj. panhard, all poly in stock front components, eibach prokit) over to the formy.
what i am trying to figure out is, are the formula springs the same as my stock iroc springs? which set of springs would be best for handling, street driving and the occasional drag strip pass with drag radials and removed front swaybar?
it seemed like the progressive rate rear spring of the prokit halped my car squat and launch better, but ive read many threads that say that the eibach kit is purely for looks and stock springs will perform better if cut for the same amount of drop. maybe i could run the progressives in the rear with the stock irocs up front trimmed a little?
ps- i wanted to run longtubes on the formula to let the (future) carbed nitroused 383 breathe better at 6500rpms.
Old Jul 10, 2007 | 10:42 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: spring swap decisions
The springs could be the same. Check the tags. There should be a yellow sticker tags on the springs themselves with a 3 letter code, the more common ones are BZW and BZX. If you can't find a tag on the spring itself, check the RPO codes. the numbers should be 6-- and 7--, the two letters after the 6 and 7 will tell what spring code they are.
Once you have that I can tell you which should be a stiffere spring.
If you still have the IROC springs and they are readily available I'd be interested in knowing what the size of them is ( height when uncompressed, number of coils, and outside diameter of coils, diameter of the wire ) and the three letter code.
I am trying to assemble a listing for the different springs that came on the cars since it seems you can get three different answers if you ask 3 people about what was available.
I just bought some Moog 5662 front springs because they are supposed to be the "stock replacement" and they are quite clearly not the same as what I took out.
Old Jul 10, 2007 | 11:05 PM
MaNiAk86's Avatar
Car: 1983 trans am
sure ill whip out the tape sometime tomorow get some measurements on those. i have not yet purchased the formula so i cant get to the spring tags.
Old Jul 11, 2007 | 09:05 AM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
just to let you know they didnt make formulas in 84 they started in 87
Old Jul 12, 2007 | 05:41 PM
MaNiAk86's Avatar
Car: 1983 trans am
i only got a measurement on the front springs and there is no longer a tag on either of them. but they are about 13.5" tall with 6 coils.
Old Jul 12, 2007 | 08:19 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
do you have the RPO code sticker in your console for the car they came out of?
Old Jul 20, 2007 | 05:04 PM
MaNiAk86's Avatar
Car: 1983 trans am
i found the tag on the springs! they were caked under years and years of grime. the fronts say BZK and the rears say NNM. sorry i didnt find them earlier.
and correction about the firebird. it is an 83 trans am(same hood as the formie).
do you think it has the quicker ratio steering box that my IROC has?
Old Jul 20, 2007 | 10:07 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
my parts book doesn't list BZK. Maybe it's either BZY or BZX?
The NNM is stiffer than what's been on any of my 3 TPI cars, 87 IROC, 88 IROC and 92 Formula all had NNL which was a step below the NNM.
Old Jul 24, 2007 | 08:04 PM
RArnold's Avatar
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
Jay --- its good to hear you are working on getting the spring info in one organized location, just one question, do you have a resource that lists spring rates for the letter codes ???
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
