front springs
Old Jul 29, 2007 | 12:08 AM
fox91rs's Avatar
Car: 1991 rs camaro
Engine: tbi 305
front springs
i put in lowering springs off ebay which suck and did nothing in the front so i think im just gonna go back and cut my stock front coils. so my question is for any one that has done this in the past, how many coils would you recamend to cut out for a good drop thats not to rediculous.
also i was wondering if anyone has expirience with wheels that are 16x9s and about how big of a wheel spacer i should go with for fronts and backs.
any info would help thanks
Old Jul 29, 2007 | 08:55 AM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Re: front springs
Before you go thru with cutting your stockers, did you index the front springs right. The car will sit way high if not. There are two holes in the control arm that the end of the spring needs to be between.
Matt
Old Jul 29, 2007 | 08:56 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: front springs
Trial and error. Cut 1/2 a coil at a time until it sits where you want it.
Old Jul 29, 2007 | 05:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: front springs
your stock springs are probably wasted, thats why the lowering springs appeared to do nothing.
Old Aug 2, 2007 | 10:57 PM
fox91rs's Avatar
Car: 1991 rs camaro
Engine: tbi 305
Re: front springs
ya i did that but i think that company that made the springs ****ed up cus they have a wide base so i dont think they sit right especially cus i have done it like 3 times to make sure its right but no luck, the lowering springs made it the same hight as before but i parked it next to another rs with stock springs and my car sat a little higher, so i dont know still thinkin about cuttin them
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
