strut mount holes off from strut mount bracket
Old Aug 1, 2007 | 02:52 PM
airblaine's Avatar
Car: 1985 Z28
Engine: TPI 400 SBC
i purchased new strut mounts from GM but when i tried to install them the original bracket that has the 3 threaded studs on it wont fit. the horse shoe needs to be bent in by about half inch to 1/4 inch. i cant find new brackets at GM or after market. am i the only one who has this problem and what should i do about it?
Old Aug 1, 2007 | 03:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: strut mount holes off from strut mount bracket
GM changed the bolt pattern at some point during the years. You could try to find used parts to fit your mounts.
Old Aug 1, 2007 | 03:12 PM
airblaine's Avatar
Car: 1985 Z28
Engine: TPI 400 SBC
thanks for the response, i found where to search the forums and there are plenty of posts on this. i will investigate spohn and junk yards for the later style strut bracket.
Old Aug 1, 2007 | 05:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should you need more info:
https://www.thirdgen.org/forums/susp...elp-quick.html
I suggest the bone yards for the part, but they're also available from Spohn.
JamesC
Old Aug 1, 2007 | 06:37 PM
airblaine's Avatar
Car: 1985 Z28
Engine: TPI 400 SBC
i went with Spohn. $25.00 for both plus $9.97 for shipping. reasonable enough for laser cut steel with S/S washers and nuts. sure a bone yard would be cheaper but then the parts need to be blasted and painted, so i took the easy way out.
Old Aug 1, 2007 | 07:42 PM
JamesC's Avatar
I bought mine from the bone yard for $10 and painted them with some leftover POR-15. Whatever works, right?
JamesC
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
redmaroz
Apr 25, 2017 07:14 AM
Genopsyde
Nov 11, 2015 10:46 PM
J.C. Denton
Aug 31, 2015 03:11 AM
