Put hotchkis springs in the back should i put LCA relocation brackets?
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
Put hotchkis springs in the back and dropped it an inch should i put LCA relocation brackets?
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Re: Put hotchkis springs in the back should i put LCA relocation brackets?
Wouldnt be a bad idea to put some relocation brackets on. They will allow you to lower the back part of the lca back down as it should be so you wont get wheelhop.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
1" drop is so-so for brackets. However, it wouldn't hurt. It might help with the wheelhop as stated above.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
LCARB's are a must with a drop.. i'm a believer.. i blew a posi from wheel hop when my car was dropped with NO LCARB's.. but i added the LCARB's after i raised the car back to stock height..
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
