What's needed to hook?
Old Aug 12, 2007 | 11:41 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Right now my car is bone stock suspension wise, and I'm having some problems keeping her on the road. After a few launches I've noticed that she's really loose in the rear end and just feels almost like I'm driving in the rain, even when it's dry.
Just wondering what suspension upgrades would help me hook better. Keeping in mind this will probably never be a 1/4 mile car, it's mainly for street and pulling some stunts in empty parking lots.
Thanks guys
Old Aug 12, 2007 | 11:56 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Re: What's needed to hook?
these cars can hook? ha ha
Maybe a four cyl....
I could be wrong but if you get it to hook, stock stuff is gonna give.
Be perpared to spend money. LCR's and possibly relocation brackets, adjustable torque arm, better and wider tires... I'm sure theres more but when you do get it to hook your rear end won't be able to handle it and then your tranny next.. or vise versa.. hopefully not at the same time....
Old Aug 12, 2007 | 12:07 PM
Daishi's Avatar
I've got my new shocks and springs in mind, cash in hand just not sure which ones to go with. After it's lowered I'll be putting on the LCA reloc brackets anyways. But along with that I just don't want to be sliding all over the road. My tranny was rebuilt 20,000 km ago, so I'm not so worried about blowing that out.
Lots of sliding out and being over the road is also my driving, but besides that I want my car to be at it's best so I'm sort of setting myself up for success if you know what I mean.
Thanks guys
Old Aug 12, 2007 | 12:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sticky tires. All the trick suspension components in the world won't help if the tires don't grab. Street tires are not very soft. Even the softest street tires are only good when they're new. They're designed with high mileage rubber. Tires that still look good with rubber can be easily old and dried out with hard rubber.
Aftermarket suspension components will always help compared to the factory stuff but try some new tires first.
Old Aug 13, 2007 | 11:15 AM
Shagwell's Avatar
Car: projects.......
springs and shocks, lca relocates, tires, bushings, and gearing. Street tires are hard compound and don't hook very well, in fact they don't hook at all. They're controlled spin. - Many of these cars came with 2.73 and 3.08 gears. The steeper gear brings your wheel speed up faster, thus will actually tend to spin worse than lower(numerically higher) gears.
These cars can be bilt to hook quite well, even on street type tires.
Old Aug 13, 2007 | 12:59 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
I think I've got what you just said - please clarify. With a numerically lower rearend (tall gears) you'll spin the tires worse than with short gears? I'm not sure I agree with that statement. I guess I could see once the tires are broken loose, the taller rear gear will accelerate to a high speed (providing your holding first gear) than the numerically higher (shorter) gear will. BUT, its a lot harder to get those tires broken loose on a 2.73 than a 3.73, if we're talking about hooking, thats always gonna be tougher with numerically higher gears. So, I'm not sure I buy that logic, at least all the way. I can see the line of thinking, but but if you think launching on a 2.73 rear end is tricking, try launching street tires on 4.11's.
No modification is gonna beat good driving and practice anyways. If the car spins right of the line, leave with a little less accelerator. If it can't stick first gear at WOT, then you'll have to pedal a little. So on and so forth...
Old Aug 13, 2007 | 02:08 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
try launchin a 385, with a stick, and 4.30's.. on old 235/55-16's.. hell, try it on drag radials even.. i have to launch under half throttle just barely tapping the 3step at 2k.. but thats in my backyard
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
stalkier
Aug 7, 2015 04:49 AM
