Offset?
Old Aug 23, 2007 | 02:51 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Offset?
What is the highest and lowest offset for wheels on our cars, I am looking at a set of wheels that have a -5 offset and was wondering if these would work on our cars. Might be a dumb question but how exactly is offset measured?
What do you think of these for our cars? I know there meant for trucks, but I like the way they look and the bolt pattern matches our cars bolt patterns.
http://www.performanceplustire.com/p...926#prodAnchor
Old Aug 23, 2007 | 08:15 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: Offset?
Anyone?
Old Aug 23, 2007 | 08:59 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Offset?
Offset is how far the mouting flange is from the center of the rim....so you need to know the wheel width to know how much offset you can run. Backspacing is the actuall measurement of the amount of rim to the back of the mounting flange.
Stock Irocs run 0 offset in the front and like +18mm in the back so those rims are going to stick out quite a bit in the back of your car.
Old Aug 23, 2007 | 09:48 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: Offset?
So +offset causes the rim to stick out from the car and a -offset causes the rim to be farther into the car. Then what is the most -offset you can have before the tire will rub?
Old Aug 24, 2007 | 11:09 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: Offset?
Bump
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
rb85TA
26
Sep 14, 2015 10:29 PM
