More sterring angle
Old Aug 25, 2007 | 03:02 AM
lsiroc's Avatar
More steering angle
Ok i know alot of people on here kind of look down on drifting, but i need help...i drive a 1990 iroc with an ls1 motor with the ls6 throttle body everything else is stock..now...ive done my inner and outer tie rods and the front spindles..... the problem is my steering degree/angle is very small, at full lock im only about half way into my slide................. ill post a vid to show u just what im talking about...
http://youtube.com/watch?v=KGNgqLw-8TI
this is not me but this is whats happening......if it could have a little more steering angle then it would kill all those little import **** cans.
Thank you in advance.... and please no flaming on the drifting........i kinda think its more exiting going sidewayz than straight (but i drag also)
Old Aug 25, 2007 | 05:19 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: More sterring angle
Do you own a welder?? There is no good way to get more steering angle without doing some serious cutting or going to a much smaller width wheel.
You are getting into the sway bar with the inside tire and the frame/brake cable/a-arm with the inside tire. The frame will be fairly easy to notch, but moving the sway bar and brake lines around to get more clearance is going to be tricky.
After you get all the interference problems figured out then you need to have your steering arms on your spindle shortened. Welding on cast iron is a bit taboo and not something I would want to trust going 100 mph sideways through a turn. Because of the unique layout of the 3rd gen front end you are not going to find any spindles that will give you more steering angle.
Unfortunately this is one of those mods that if you have to ask then you probably don't posses the skills necesary to make the changes.
Old Aug 25, 2007 | 09:12 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
That's been brought up here before, in this thread - - -
https://www.thirdgen.org/forums/susp...ing-angle.html
but also at the domestic drifting forum.
http://www.driftingforums.com/phpBB2...steering+angle
What I've doen for now is run 2 inch spacers in front with low offset wheels.
So far I can use all of my angle without rubbing, I can go all the way to the stops. If you check the link you see that the G body YA box has a few more degrees of angle (different stops inside). My proposed idea is to use one of these boxes and then shave just a bit off the outside stops on the front lower control (A) arms.
Got any pics or vids of the Iroc in action?
Old Aug 25, 2007 | 01:11 PM
lsiroc's Avatar
thanx for the info... hey soultron i am a member on the driftingforums.com but i just read more than post.....but ill try and see if i can source out a g wagon or sumthing for the front susp. thank you again.....ps pics and vids in the works....the car is up on jacks right now for a stiffer 600lb coilover setup......can anyone help me out with a good shock to work with the 600lb coils that are up front....and 500 out back
Old Aug 27, 2007 | 04:27 PM
BMmonteSS's Avatar
Car: 84' Monte
If you are truely running 600 lb/in coil overs you are in for a ride. Thats the equivalent of running 1200 lb/in springs in the stock location. You'll need something in the 350 range in the back to balance it out, probably stiffer to make it loose.
The modifications that soultron speak of will get you a few more degrees of travel, but nothing like what I've seen done to the "pro's" cars. They are capable of well over 45 degrees of steering angle.
Old Feb 22, 2008 | 11:18 PM
soultron's Avatar
Car: 87 trans am
actually the Gbody has close to 40 degrees as it is and I think I have a way to get the other 5 or so, but yes, there's gonna be cutting. and heart break.
Think of it as me helping others raise the value of their cars.
jbates346
Oct 21, 2015 01:50 PM
mfp189
Sep 27, 2015 09:25 AM
Linson
Sep 21, 2015 01:08 PM
FED 387
Sep 16, 2015 12:18 PM
Night rider327
Sep 16, 2015 02:20 AM
