I need to know about my sway bars
Old Aug 30, 2007 | 09:59 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I have a 1987 IROC-Z with front and rear stock sway bars. I was just wondering what size they are and if they are hollow or solid.
Anyone know?
Old Aug 30, 2007 | 10:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: I need to know about my sway bars
Looking is the only way of truly knowing. The hollow 36 mm, solid 24 sways didn't come along until 89 in the Camaro, so you "probably" have the 34 (could be hollow. Look for a drain hole near the end link), solid 24 combo.
JamesC
Old Sep 4, 2007 | 10:38 AM
Car: 1987 IROC-Z
Transmission: TH350
ok, I looked and I have a solid 24 rear and hollow 34 front.
How much weight do you think I would gain if I would change the front to a solid 1 3/8" and would I be able to notice a differance?
Old Sep 4, 2007 | 11:38 AM
JamesC's Avatar
In the general scheme of things, the weight would be insignificant. I doubt that you'd be aware of the difference.
JamesC
Old Sep 4, 2007 | 03:34 PM
Car: 1987 IROC-Z
Transmission: TH350
Sounds like I should stay with the stock bar.
for the advice.
Old Sep 4, 2007 | 04:51 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
I have the same size. Stock had 1 more size bigger 36/25 but not much of a substansial gain IMO. I did Eibach springs, poly bushings and endlinks on the bars, poly LCA bushings up front at the same time and that is where I noticed a much improved 'rail-like' steering. Added a GWest wonder bar, already had Lakewood rear LCAs and Panhard. I also had the rear bar bushings and links done. All in all I love it. Thought about getting the 36 front..have access to one, but decided Im good =) I also did new steering linkages (all) and lower ball joints. Better than new IMO
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
