Were Will These 4th Gen Wheels Sit On My Roc?
Old Jan 5, 2007 | 05:06 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Im looking at a 88 Iroc this weekend and it needs wheels and a paintjob, so I have a quick question for you guys.
Ive got a good deal on a 4th gen disc rear and I would like to install it on the car if I get it, so ive been wanting to run these wheels on this car, they have a 4th gen offset and im just curious with the 4th gen rear and 2" spacers up front were will these wheels actually sit on the car?
This a 4th gen running the same exact wheels and tires I wanna run, with the rear and spacers up front will they sit close to the car pictured?
18x10 (41mm Offset)Rears and 295/35/18s Tires 4th Gen Rear
18x9 (25mm Offset)Front and 275/35/18s Tired 2" Spacer
http://cgi.ebay.com/ebaymotors/18-x-...QQcmdZViewItem
So does anyone have any pictures or info of about were they will sit on my Car?
Attached Thumbnails Were Will These 4th Gen Wheels Sit On My Roc?-ws61.jpg   Were Will These 4th Gen Wheels Sit On My Roc?-ws616.jpg   Were Will These 4th Gen Wheels Sit On My Roc?-camaro2000013.jpg
Old Jan 5, 2007 | 10:31 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Damn, everyone is finding out about these wheels now! I have a black set sitting in boxes waiting for tires. Two people I talked to that had them said they didn't use a spacer for the rear and one used a custom 9/16" and the other a 3/4" for the front (both with longer studs) to clear the tie rods. Since I have rear disk brakes the wheel hits the e-brake cable and it comes awfully close to the inner wall of the wheel well so I'm planning on just going to run 1" adapters all around so the wheels are all even. I'm going to go with 255/45/17 tires so they're the same diameter as stock. I'm going to buy the tires before the adapters just to be sure they won't stick out of the wheel well.
Old Jan 6, 2007 | 02:27 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
anybody have pics of them on a 3rd gen? curious to see how they fit in the front
Old Jan 6, 2007 | 09:12 AM
Car: 2012 Corvette
Engine: LS3
Those two people I mentioned that I talked to above both had Pontiacs. Here is Tom91Bird's car with 17" chrome:
You should see of Ron's Rims (eBay name: edinboro) and see if they can get you a good price on them.
Old Jan 6, 2007 | 06:07 PM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
Sounds like im gonna have to bite the bullet and order them and hopeI get them to fit.
Do you guys think the 18x9 and 275/35 tire might rub any if I put them on so they are close to the outer fender lip on the front?
Old Jan 6, 2007 | 07:55 PM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
Whats the size and BS on those 17" wheels?
Old Jan 6, 2007 | 08:19 PM
Car: 2012 Corvette
Engine: LS3
17"x9" so they have a +24mm offset and 6" of backspacing.
Old Aug 13, 2007 | 06:08 AM
BOTTLEDZ28's Avatar
Transmission: A4
Re: Were Will These 4th Gen Wheels Sit On My Roc?
KonArtist, did you ever get these wheels? If so how did the front wheels fit? Im looking at a set fo 17x9 wheels with a 25mm offset. Im hoping I do not need spacers to run these. let me know
Old Aug 13, 2007 | 08:41 AM
Car: 2012 Corvette
Engine: LS3
You will need a 1" adapter, and if you get 275s all around they will line up perfectly with the top edge of the wheel well, and it looks perfect that way.
Old Aug 13, 2007 | 08:44 AM
BOTTLEDZ28's Avatar
Transmission: A4
compuwiz1937, are you speaking from experiance with wheels this size? How come such a big spacer? The chart states the wheels will move in 1/2". Do you have any pics of this setup
Old Aug 13, 2007 | 11:23 AM
Car: 2012 Corvette
Engine: LS3
Yes, my wheels are 17x9 with a +24mm offset. Our cars need 0mm offset, and a 1" adapter is equal to about 24-25mm, so that will put the offset around 0mm. My car:
Old Aug 13, 2007 | 11:57 AM
BOTTLEDZ28's Avatar
Transmission: A4
ok thanks for the heads up. BTW, your car looks nice with those black wheels. Im going to have to see what I can do to get the wheels I want to fit nice on my car.
Old Aug 14, 2007 | 08:30 AM
Car: 2012 Corvette
Engine: LS3
Thanks.
That's the only thing about this offset with that size wheel, the tires do rub in the front. A few people I talked to before I bought the wheels were using slip on spacers, and said they had no tire rub. Since slip on spacers are not safe, a 1" adapter is the only real choice (I asked just recently because I wanted to try and put a stop to the tire hitting the a-arm at full lock [only one side does that]). Besides, a wheel this wide up front can't be moved in much or it'll hit the strut and tie-rod anyway. I added the quick ratio steering box back to my list of stuff to do since it doesn't turn the wheels as far as the standard box so that should stop the tire hitting the a-arm, or once I do my LS1 swap and have tubular a-arms it won't hit anymore.
Old Sep 4, 2007 | 04:42 PM
Jeffluke's Avatar
Car: 90 L98 IROC/87 LB9 NM5 1AZ / 96 TBI 350 700R4 XCAB S-10..LT1 SOON
Engine: L98/LB9/LT1
Transmission: 700R4/WC-T5
Axle/Gears: 3:73
I am trying to locate a 1" adapter/spacer kit, does any one know of a kit for a good price, the cheapest I have found is @ $75 per wheel......@300 for the set locally in Va........any help would be great.....Jeff
Old Sep 4, 2007 | 04:44 PM
Car: 2012 Corvette
Engine: LS3
I got mine from eBay.
Old Sep 4, 2007 | 08:26 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
my car had stock 4th gen wheels with 2" spacers front and rear... my sig pic is like that. I have a 4th gen rear now with no spacers and this is the best pic i have of where they sit.
Attached Thumbnails Were Will These 4th Gen Wheels Sit On My Roc?-sspx0645.jpg
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
