Pulls off the Road
Old Sep 3, 2007 | 09:23 AM
19kilo's Avatar
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
Pulls off the Road
My car some times wants to pull off to the right bad also when I turn it right I hear a grinding noise some one told me it was something hitting my exhaust in the back???
Old Sep 3, 2007 | 09:51 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Pulls off the Road
My truck always wanted to pull off the road to the right while driving down the road. It seemed like I was always holding the steering wheel to the left. When I go my race car on an alignment rack in the spring, I also put my truck on to check the alignment. The toe was out slightly and was adjusted. The truck still pulled to the right.
About a month later I developed a sidewall leak and needed new front tires. After the new tires were installed, the "wanting to pull off the road" went away. I can let go of the steering wheel now and the truck goes straight down the road.
Nothing should hit your exhaust in the rear while turning. Where is the noise coming from? Jack up the front of the car and check your wheel bearings, suspension and steering components. If you don't know how, take it into a garage and have a mechanic look at it.
Old Sep 3, 2007 | 09:53 AM
19kilo's Avatar
I dont know really hard to tell like a grinding noise only happen when truning to the right.
Old Sep 3, 2007 | 10:44 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the y pipe comes pretty close to the right wheel when turning right, at least my SLP one does, that may be the grinding/rubbing. My car always wanted to drift to the right, got it aligned and it still did it. it ended up being that the balljoints on my centerlink/draglink were shot.
Brother Al
Oct 14, 2015 06:39 AM
86IROC112
Aug 31, 2015 07:00 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
