center link / idler arm adjustment
Old Sep 10, 2007 | 09:04 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Can anyone tell me how to check the height on the idler arm? I replaced all the front end stuff and I can't find the paper that came with the center link about how to check that it's correct. It's something to do with a straight edge going over the flat ground on it.. and measuring the distance somewhere. I glanced at it quick, but I may have thrown it out.
It's going in for an alignment but I'd like to get the car close as I can so I can drive it to the shop.
Old Sep 10, 2007 | 10:53 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Re: center link / idler arm adjustment
All I ever done was to make sure that it was level. Thats about all you really have to do with the center link / idler arm.
Old Sep 10, 2007 | 11:11 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The idler arm needs to be adjusted so that it is at the same height, relative to the frame, as the pitman arm. You can measure each from a common reference point, or, if the front of the car is on level ground, adjust the idler arm so that the center link is also level.
Old Sep 10, 2007 | 10:31 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
I looked it up in the service manual... kinda forgot that it would be in there
I figured it needed to be level... and when I put it in where the old one was it looked off so I eyeballed it.. I'll measure how the service manual says, which is to put a socket on the ARM bolt head then use a "special tool" which looks like a slide square to me and measure off the flats.
Ghettobird52
Apr 21, 2020 08:44 PM
db057
Sep 4, 2015 07:57 AM
zayne0
Aug 24, 2015 07:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
