Strange vibration
Old Sep 13, 2007 | 06:52 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Strange vibration
I have had this vibration since I bought the car.
New rims and tires all around didn't fix it.
Engine swap didn't fix it.
New springs and shocks (front struts still need to be replaced) didnt fix it.
The car does not pull, but I never did an alignment either, because the struts are bad and I wanted to replace them first.
The vibration occurs ar 60-75 miles an hour. It is much much worse in the rain. This leads me to believe that it is an alignment problem.
What are your thoughts?
Old Sep 15, 2007 | 01:17 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Re: Strange vibration
could be as simple as a wheel bearing not preloaded correctly
or a strut mount
getting worse in the rain really makes me think it may be either one of those
Old Sep 17, 2007 | 04:08 PM
Toehead's Avatar
Any way to check to see if it is the wheel bearing?
I think the strut mounts are alright... They look alright at least!
Old Sep 17, 2007 | 04:25 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Highly doubtful the alignment will cause a vibration. Recheck the balance of the wheels, look for something caught in the vents of the rotors or a weight broken off a drum if you have rear drums. Driveshaft balance or dry, stiff u-joints is a possible cause, worn ball joints.
The best thing to do with the wheel bearings is clean them look for hot spots and galling in the rollers themselves and repack them yourself then you will know they are right.
Old Sep 17, 2007 | 08:09 PM
Toehead's Avatar
Wheels have been balanced at least 3 times each since i've owned the car. It may be the driveshaft... It is original.
I tend to think it is coming from the front because it can be felt clearly through the steering wheel.
Old Sep 18, 2007 | 07:13 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
After I posted I figured you would have probably already re balanced the tires. If you feel it in the wheel more than the butt dyno then I would agree to concentrate on the front end. Ball joints, control arm bushings, steering linkage, wheel bearing as stated before, steering grearbox mount, unbalanced brake rotors. All are possibilities thing I have seen cause this.
How strong is the vibration? A lesser strength vibration that would lead me to think a component balance problem, sometimes you can drive past the worst of it at higher speed. A more violent vibration that gets worse with higher speed would lead me to worn parts.
Good luck hope this might give you some ideas.
Old Sep 18, 2007 | 08:53 AM
Toehead's Avatar
Ya... It goes in and out. It kick in a about 65, the worst is about 68, then its gone by 80.
Old Sep 18, 2007 | 10:08 AM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Are u SURE it's coming from the front? Read this post about my vibration problem:
https://www.thirdgen.org/forums/susp...tion-88-a.html
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
