open diff to posi?
Old Sep 13, 2007 | 07:26 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
open diff to posi?
I have a 89 Camaro RS with an open diff with 3.42s. What posi unit would I need to look for to make the rear posi besides buying an axel out of a IROC or TA. I'd like to keep my gears.
Old Sep 13, 2007 | 08:01 PM
1990_RS350's Avatar
Re: open diff to posi?
to change to posi wouldn't you have to change your gears?
or do you mean u don't wanna change ratio?
Last edited by 1990_RS350; Sep 13, 2007 at 08:02 PM. Reason: Automerged Doublepost
Old Sep 14, 2007 | 08:57 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I thought that you could change to posi but keep the gears...I don't know where I got that idea. I would like to keep the 3.42 gear ratio so that I don't have to mess with the speedo cable. Otherwise what is the axel size and such so that I knwow what I would have to buy.
Old Sep 15, 2007 | 12:42 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
You can change the non posi carrier with with a posi carrier and be done. NO problems. your 3.42 car now has a posi. You don't have to change gears.
Cheers!!
Old Sep 15, 2007 | 01:10 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
^exactly
what you're looking for is a posi carrier to be installed, that is all. totally do-able
Old Sep 15, 2007 | 01:46 PM
1990_RS350's Avatar
ah... cool, i wasn't too sure about that... i've never done a rearend before...
Old Sep 15, 2007 | 04:26 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
well you could also use a locker that replaces the spider gears. If you use another carrier you have to put new bearings on (at last you should) the you hav to shim it right including using the proper tools to get it within a few .001". I've done it and it's kinda hard, plus the spider gears will probably blow up later anyway (if you drive hard like me). eliminate the weak point in my opinion. or you could just get another rear end from the junkyard that already has a posi and just change the fluid and don't drive like a road racer.
Old Sep 15, 2007 | 10:32 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
I think what he is talking about is what series gears does he have? It could be series II or III It's hard to tell with out looking.Could be either one with 3.42 gears. If I had to bet I would put my money on them being series III. Also 89 was a change over year between the 26 and the 28 spline axles. I think the 2.73 got the 26 spline the rest got the better 28 spline axles.
Old Sep 15, 2007 | 10:53 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I would need all that sort of info to find out the right carrier that I would need. Really this would be a rearend rebuild with new bearings and such. There is something in my rearend making this clunking/popping sound with side to side movement.
Old Sep 15, 2007 | 11:18 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
OR JUST BUY A POWER TRAX NO -SLIP TRACTION SYSTEM FROM JEGS 449 DOLARS
THAT MIGHT WORK sorry about the caps
Old Sep 16, 2007 | 12:21 AM
89rsragtop's Avatar
Car: blue
A rear end rebuild is not something to just jump into if you have never done one before. It takes skill and knowledge and the proper tools. The popping / clunking sound with side to side movement is most likely a loose brake shoe. Check the hold down pin and spring on the shoe. Or maybe a bad wheel bearing. Also carefully inspect your panhard rod.
Old Sep 17, 2007 | 02:53 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
i wouldn't touch the gears. I know that in the rearend you want the gears centered perfectly or you mess then up bad.. I wouldn't even know where to begin to do the gears. I could do the bearings. My dad has experience doing bearing so I can get his help.
Still does anyone know splines, size of the axel, etc so that I can get the right posi unit, I would like to buy a used one. Its only going on a V6 so I'm not really worried about blowing out the rear.
Old Sep 17, 2007 | 05:01 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Unfortunately, you car was built in the "changeover" period, so the only way to tell what you need is to pull apart what you already have and look.
Old Sep 17, 2007 | 05:21 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Damn, I'm really not in a position to just trear apart the rear, its my DD. I guess that there is no way to tell from the outside.
Old Sep 17, 2007 | 05:48 PM
Car: 87z28
Engine: 70 LT1
your rear end is a type 26 here is a picture of it after 411 gears wer built in.. I found this when i did a search hope it helps
Old Sep 17, 2007 | 06:04 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Ok thanks. So type 26 as in 26 spline? I believe that the rear is a 9 bolt...
Old Sep 17, 2007 | 06:22 PM
Car: 87z28
Engine: 70 LT1
please check your rear axle to find out what gears you have first ok here is what you look for on your car ok hope this helps and then we can answer your question ok
6HB3.08:16HP2.73:1 8EW3.45:1 6HE2.73:16HT2.73:1 9ER3.45:1 Locking6HF3.08:18ET2.77:1 9EQ3.27:1 Locking6HK3.08:18EU3.27:1 9ET2.77:1 Locking6HL3.42:1 look for any of these they should be on your axle thanks
Old Sep 17, 2007 | 09:06 PM
krisb410's Avatar
Then just buy a whole rear unit with the posi, the gears, and the brakes you want. Then swap out the whole thing in one day.
F-body driver
Mar 6, 2023 11:44 AM
Numbah-1
Sep 12, 2015 08:57 PM
carattini
Sep 10, 2015 07:46 AM
georgiaslim45
Sep 9, 2015 08:11 PM
toyotekk
Sep 6, 2015 02:21 PM
