is my power steering gear box ok?
Old Oct 2, 2007 | 07:00 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
just got a quick ratio gear box off ebay, is there any way to tell if it's good without bolting it on?
the engine is not in the car yet.
thank's guys!
Old Oct 2, 2007 | 07:39 AM
Re: is my power steering gear box ok?
They don't "go bad" much, except by leaking, and needing adjustment.
Leaking should be somewhat obvious. I don't think you need help with that.
To adjust it, you back off on the lock nut and Allen in the top cover; back off the great big sheet metal lock nut on the worm shaft adjuster, and adjust that until it takes about 2 inch-pounds IIRC (it's been a while since I did one, so I forget the exact #s) to turn the shaft; then tighten the Allen thing until it takes about 4 inch-pounds or so to turn it. Your service manual will give you the right torque values, don't trust mine, they're just for illustration.
Old Oct 3, 2007 | 01:23 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
thank's sofa!
as always.
Eric B
Old Oct 5, 2007 | 01:37 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I had my steering box rebuilt by these guys. They're very knowledgable on the subject.
Red-Head Steering Gears
206 364-3333, 1-800-808-1148
900 N 127th St
Seattle, WA 98133, United States
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
InfinityShade
Aug 22, 2015 08:00 PM
