Want to lower front end after LOTS of weight loss
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
So far Iive pulled about 250lbs out of the nose of my car. Only things left in the nose is the motor w/ aluminum heads, and and water pump/ALT. The nose now sits a bit high even with the V6 springs in there. I saw those moroso 150lb springs, would those be too soft? I want the front of the car pretty low, and then to spring up on a hard launch. Car is mostly a track car now.
Any idea on cheap ways to do this? Planning on swapping over to a tubular K member/coil over set up later next year.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Want to lower front end after LOTS of weight loss
For a track only car, get the Moroso trick springs. Cut coils to get the ride height you want. I use the BBC springs uncut in mine.
Terrell351
Jun 13, 2021 01:13 PM
