strut bar for a v6
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Re: strut bar for a v6
Got mine from BMR Fabrication. Two mods I found to be needed though...
1) didn't sit flat on the strut towers initially. Put it on the ground, have someone hold it and GENTLY step on it to spread it (mod courtesy of my 13 year old son- thanks, Tyler)
2) I found some SLIGHT contact with the AC pump- had to take the dremel and grind a very small notch in it to clear. I need to install SFCs yet, so that should prevent the flexing that cause the interference in the first place....
All in all, a good product that works well- but get a Wonderbar too... that made a MUCH more significant difference than the STB.
LT1Formula
Oct 8, 2015 08:34 PM
