Widest tires on stock RS rims
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I need new tires on the rear rims, What is the widest tires that I can safely put on the rims. They are the stock 15" RS rims. Its an 89 Camaro, I'm not lowering it in the future, too hilly around here for my taste on a lowered car. The tires on there now are 215 65 15 I believe. I would like to get 255s but that may be pushing it. I want a wider tire for the rear for looks too.
Car: 1992 RS Camaro
Engine: 5.0 tbi
Axle/Gears: stock 10 bolt 3.08's
Re: Widest tires on stock RS rims
IVE GOT 265/50/15 ON MINE RIGHT OW FIT GOOD NICE LARGE FOOT PRINT BUT A HAIR SHORTER THEN THE STOCK 215 THOUGH. ALSO HOOK NICE TOO NO RUBING BUT I ALSO HAVE RAN A 275/60/15 WITH ONE INCH SPACERS ON THE TOP OF THE SPRINGS AND ALSO RAN 255/60/15 WITH NO SPACERS BUT CANT CARRY NO ONE OR IT WILL RUB OVER THE SLIGHTEST BUMP
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I agree with 85zed....a 265 60 or 275 60, even a 275 50 for that matter will cause the speedo to be out due to the tire being 1" (or more) taller than the original tire.
A 245 60 is the biggest and tallest I would go.
Between a 255 60 and a 245 60 you are only gaining 0.2" of width....just something to think about...............good luck
Car: 89 IROC
You put a 295 on a 7" rim without and ride issues (side wall budgling) and your speedo is not out with the taller tire?.........
